Tank Trap
thegiff
Real Name: JackBlack
Tank Trap
Post by thegiff »
How long are the tank trap poles? I picked up some material from a really big pallet and have a couple of decent quality 4X4's long enough to make one. I think they are 9 or 10 feet long. Seems like tank trap poles are about 4 feet each but I wanted to not start off with them too short.
:ban:
Re: Tank Trap
If I remember correctly I cut mine at 4'x4'x5'
thegiff
Re: Tank Trap
Post by thegiff »
Built the tank trap today, here it is...
2 poles are 5' long (60")
1 pole is 64" long.
If too long, easy to cut shorter, relatively difficult but not impossible to make longer though.
Wood, as I mentioned, is from a scrap pallet. It is light, mostly pretty smooth, but of course has some nail holes. Free is good, I'll take nail holes over paying for it cuz I'm cheap.
Arranged by clamping together until it looked about right, then drilled the holes. Measure, mark, drill, check, repeat. 2 bolts holds it together but no matter how tight it was loose, so I added the 3rd bolt I bought to tie it securely. Held with 5/8" diameter bolts 10" long. Should have bought 8" long bolts, I'll just cut them. Two of the poles the holes are 5/8", one of the poles the holes are 3/4" to make it easier to put together. I ran a roundover bit over the all the surfaces including the holes, this should help reduce splintering.
I'm thinking it would be nice to weld teeth onto the bolts so that I only need one wrench instead of two, I've got do some welding tomorrow anyway so I'll throw that in...
:ban:
gau17
Real Name: Solomon
Re: Tank Trap
Post by gau17 »
Nice Aaron. It would be to shoot that thing with bar wires.
