Angeles 10/12...
evo
Real Name: Evin Grant
Angeles 10/12...
Post by evo »
Need to do some load work and zero the new Razor, anyone want to join? If we can get 5+ I can do the blue sheet, $7 each.
buffybuster
Real Name: Enrique Cancion
Re: Angeles 10/12...
Post by buffybuster »
I'll be there
I'll try to come out to play...
flyingspur
Real Name: Kevin
Post by flyingspur »
I will be there, finalize hunting load for 300WM...
Pre-visualize and don't rush...
flyingspur
Real Name: Kevin
Not to worry, I will shot on east side of rifle range. My chrono doesn't like tree shadows.
It might be on its last leg though, was getting random readings last time in the sun....
flyingspur wrote:Not to worry, I will shot in east side of rifle range. My chrono doesn't like tree shadows.
It might be on its lady leg though, was getting random readings last time in the sun....
Your chrono sounds like it's performing normal to me....
flyingspur
Real Name: Kevin
DirtRacer151 wrote: Your chrono sounds like it's performing normal to me....
Can you elaborate on that? Any tips on using a Pro Chrono Digital model?
I know it likes overcast days, but it usually gives reliable velocity reading in the full sun. It can be affected by muzzle blast from nearby benches, at least mine does. I have learned to filter noise and throw out a few outliers.
But last time it didn't do well in the very beginning. I was shooting ABLR 210, 76.3gr H1000, out of a 300WM with 24" barrel. Its velocity should be around 2750 to 2800 fps, which I know based the past test of 76.1gr and 76.5gr. Also confirmed by 300yd shots later. Here is data I got during my first 8 shots period. There are 45 velocity data recorded! Only one of them seems make sense, that is 2777 fps. The Duracell battery is not fresh, with a few hours usage on it. No err or low battery message. Not sure what happened. :?:
But later it did settle down and give reasonable velocity reading. So I need to go back Sunday and test again.
2682
2693
3259
1011
1009
3527
3623
2175
2129
1969
178
2157
1049
2116
2777
2126
2106
2812
2126
2083
2076
2067
2666
2063
2842
2093
2070
2073
323
3418
2063
2057
2048
2048
2038
2041
2604
2011
2594
2002
2609
2026
2038
2005
2559
2515
evo
Post by evo »
I'll have my Magneto for reference.
flyingspur
Real Name: Kevin
evo wrote:I'll have my Magneto for reference.
Great, we can cross check my pro chrono. Thanks
Downrange67
Real Name: Henry Garay
Post by Downrange67 »
Evin, I'll be working on load development, would it be ok if I shot a few with your magneto?
Tomorrow's Battle Is Won During Today's Practice!
evo
Post by evo »
Of course
My point is that chronos are inconsistent and finicky pieces of shit. It sounds like yours is living up to its reputation. People who use them are pretty much wasting time and barrel life shooting through one.
flyingspur
Real Name: Kevin
Dope is the king. But a chrono is still useful for finding loads with low ES.
flyingspur wrote:Dope is the king. But a chrono is still useful for finding loads with low ES.
Useful in theory. The problem is they're rarely ever accurate enough to give you accurate results.
You could just be like Ryan Kerr...pick a load...no OCD leading techniques....shitty reloading equipmemt....go out and win the national finale on a barrel with 2500 rounds through it using the same load as day 1. That might be to simple for you though.
gau17
Real Name: Solomon
Post by gau17 »
Fuck that guy...
You forgot Drunk!!!
flyingspur
Real Name: Kevin
I wish it is so simple. To win at that level, talents and training matter a lot more than a gun capable of tinny groups.
I spent as little effort as possible with reloading. I tumble the brass for 10 minutes, neck size it with lee, use redding body die only when it is absolutely necessary, throw every charge. I don't check run out much now since I learned to use good brass...
But I do have a confession to make, I mess with too many different guns and bullets. A large portion of my range time was spent on finding a good load for this gun with that bullets. :doh: From now on I will focus on one gun for shooting match, might be a couple of guns for hunting :lol:
evo
Post by evo »
My trip down the OCD rabbit hole did me no favors at Surefire, in fact it actually contributed to my mental fuck up. It seems to work for Solomon but I was doing fine with just the chargemaster before.
evo wrote:. It seems to work for Solomon
SoRomon doesn't know it but he would be a good shooter with or without OCD.
gau17
Real Name: Solomon
Post by gau17 »
How does being OCD mess up your shooting up? It wasn't operator error?
gau17 wrote:How does OCD mess your shooting up? It wasn't operator error?
You've mentally fucked yourself over more then once this year because of OCD...
evo
Post by evo »
gau17 wrote:How does being OCD mess up your shooting up? It wasn't operator error?
Absolutely it was operator error, or more to the point operator hubris. I decided to push my load to the top of the node since I was able to charge so accurately with the AND scale. Of course I completely spaced on the fact it was going to be 90°-100° in Tehachapi with 10 shot strings, which as expected pushed me out of my node. I suppose it was a good lesson to learn but one I should have realized in the first place. Although something is still making the gun shoot .2 mils right after the first couple rounds, either the scope or the muzzle brake (according to Ray).
gau17
Real Name: Solomon
Post by gau17 »
Not true. Well not completly. LoL.
Utah my hybrids stopped grouping because the lands moved too far. I still can't get them to group past 200. No my fault.
The other time you might be correct.
gau17
Real Name: Solomon
Post by gau17 »
.2 is a lot. Try shooting without the brake
evo
Post by evo »
I'm going to track it down Sun.
evo
Angeles 10/12...
Post by evo »
Anyone have a set of Med. or High 34mm rings I can use on Sun.? The 56mm Razor touches the barrel with the low ARC rings.
gau17 wrote:Fuck that guy...
You forgot Drunk!!!
But according to someone else, Kerr doesn't know what he's taking about...
Lol
buffybuster
evo wrote:Anyone have a set of Med. or High 34mm rings I can use on Sun.? The 56mm Razor touches the barrel with the low ARC rings.
I have a set I can bring.
The integral rail on a surgeon is lower than a bolt-on rail used on 700's so I have commonly run into needing to run 1 size taller rings on surgeon receivers.
I think I have some medium badgers if you want to try them.
I'll be here all day...
evo
Post by evo »
I canabalized a set of Med. Badgers from a DMR, it clears now but only just.
gau17
Real Name: Solomon
Post by gau17 »
Good practice today
