Parallax setting for multiple distances....
postal
Real Name: Julian
Post by postal »
I just want to double check.
Shooting a drill back and forth between 2 different distances... Hold over between the distances, not time to adjust parallax or elevation...
Parallax/focus should be set to the *FAR* distance right?
The far distance is where parallax will hurt you more, so it should be set right at the far distance... and even if the image is blurry for the closer distance, "suck it up". Right?
buffybuster
Real Name: Enrique Cancion
Re: Parallax setting for multiple distances....
Post by buffybuster »
postal wrote:I just want to double check.
That's the "usual" way, but you have to find what works for you. If the two distances are too far apart, then you might want to settle on a in between compromise.
264Charlie
Real Name: Charles R.
Post by 264Charlie »
I set it for the in order of
Hardest, most likely to be in poor position, shot
If equal
the smallest target
If equal
Middle distance to split the error equally.
Sent from my iPhone.
Short Action Precision
Real Name: Nathan Webnar
Post by Short Action Precision »
I do the same as Charlie. I always set my dope or Parallax for the target with the most difficulty. If they are all difficult then some where in between.
264Charlie wrote:I set it for the in order of
If equal
the smallest target
If equal
This sounds exactly like what I would say.
postal
Real Name: Julian
Post by postal »
Thanks all.
