We had four 1st time Caprc match shooter.
Steven and Randal ran the match.
Mike,John, and Nick helped run the line.
Total round count for the day was 50.
There were 10 stages with 1000 total points possible.
400 yard cold bore
On the start signal, engage the 1/3 IPSC flapper with 1 shot from the prone position.
Start position is standing with rifle at port arms, loaded magazine with the bolt back.
1 round
70 points possible
60 second shoot time
60yd Poolballs
On the start signal, engage the poolballs with 1 shot from the support side
(support side trigger finger) prone position. The 8 ball is optional. A hit to the 8 ball
without also hitting all other solid balls causes the shooter to loose all points. 10 points
per ball except the 8 ball is worth 30 points or zero if all solids are not hit
8 rounds.
Pack Support
On the start signal, engage the 300yd IPSC with 6 shots from the prone position off
a pack. You may not use a bipod or rear bag. The rifle must only be supported over a pack.
6 rounds
Scoring per the target
90 points possible
Sitting Unsupported
On the start signal, engage the specified 100yd IPAC target with 5 rounds from the seated position.
5 rounds
Kneeling Unsupported
On the start signal, engage the specified 100yd IPSC target with 5 rounds from the kneeling position.
5 rounds
Random Callouts
On the start signal, engage the specified yellow targets with 2 shots each from
the prone position as they are called out. The targets are the following: 12" dot at 600,
10" dot at 500, 8" dot at 400, and 6" dot at 300.
8 rounds
20 points per hit
160 points possible
80 seconds shoot time
Kneeling supported transitions
On the start signal, engage the 350yd hostage, 200yd little man, and 100yd
2" shoot-n-see from the kneeling position over the bench in the following
order: 100-200-350-200-350-200-100. No artificial rear support may be used,
bare hand only.
7 rounds
105 points possible
Stressfire
On the start signal, run to your rifle and engage the 200yd little men from left
to right with 1 round each. Shooter starts with 1 round in his hand and must
retrieve each additional round from the bench behind the firing line.
4 rounds
25 per hit
70 seconds shoot time
Standing unsupported
On the start signal, engage the specified 100yd IPSC target with 5 rounds from the offhand position.
5 rounds
125 points possible
Hotbore
On the start signal, engage the 100yd 3/4" square with 1 shot from the prone position.
50 points for a hit
50 points possable
10 second shoot time
610 Danny N (Top .308)
545 Matt C
495 Rich C
490 Solomon M
460 Mike Y
440 Eddie J
440 Evin G
295 Charles H
270 Ronny S
230 Alfred G
190 Kyle A
