Caprc 5-27-12 match AAR
GforceJunkie
Real Name: Mike S.
Post by GforceJunkie »
We had 14 shooters show up to shoot today's match.
Brad ran the match.
Mike S, Steven and others helped run the line.
Total round count for the day was 48.
There were 10 stages with 1150 total points possible.
Match rules:
Bolt must be open during any position changes.
5 rounds maximum in the gun at any time.
All stages start standing behind rifle, ammo in rifle, bolt open unless otherwise specified.
200yd coldbore
On the start signal, engage the left square of the 200yd hostage target with one shot.
55 points for a hit completely inside the scoring square.
-20 for hostage hit
55 points possible
30 seconds prep, 20 second shoot time.
Barricade
On the start signal, engage the 350yd 10" green plate with 2 shots from each of the following positions: standing, kneeling, seated, and prone, using barricade for support.
15 points per hit.
120 points possible.
60 seconds prep, 100 second shoot time.
Timed Exposures
On the start signal, engage the 400yd springloaded red ipsc plate with 2 shots. Each time the target becomes visible, engage with 2 more shots.
First string is 16, seconds, then two random 6 second strings.
Positional KYL
On the start signal, engage the 250yd 8" yellow/blue circle with 1 shot from each of the following positions: prone, seated, kneeling, then standing. You may stop at any time. A miss caused the target to be zeroed.
Point values: 10, 30, 40, 50.
130 points possible
60 seconds prep, 120 second shoot time.
Little Hostages
On the start signal, engage the 5 hostage takers at 25yds with 1 shot each.
Rounds striking 2 scoring areas will be scored as only one hit
Rounds striking a hostage and a hostage taker will be scored as a hostage hit.
60 seconds prep, 40 second shoot time.
Speed Drill
On the start signal, engage the specified green targets with as many shots as you can. A shot after the par time will cause one hit to be removed during scoring. Ths stage starts with the shooter on target, bolt closed.
20 points per hit
60 seconds prep, 10 second shoot time.
200yd hostages
On the start signal, engage the 3right square of the 200yd hostage target with 5 shots.
12 points per scoring box hit, 10points for any other hostage taker hit. -20 for any hostage hit.
10o points possible
60 seconds prep, 20 second shoot time.
KYL
On the start signal, engage the circles from largest to smallest with 1 shot each. You may stop at any time if you are not sure you can make the shot. A miss causes all stage points to be lost.
Circle values: 10, 15, 20, 30, 50
125 points possible
Time ticking down.
On the start signal, engage the 6" red circle at 300yds with 1 shot. This stage is fired as 5 separate passes, with descending par times per pass as follows: 17, 14, 11, 8, an 5 seconds. Shots after the par time wil cause one hit to be removed during scoring.
20 points per hit
60 seconds prep.
Man on Man
On the start signal, engage the 200yd yellow little men with one shot each from outside to inside. You must hit each plate before you proceed to the next. All shooters earn their hit points. Fastest shoot moves to next round.
25 points per hit
1st: John Lee
2nd: Mike S.
3rd: Rich C.
Top .308: John Lee
Man vs Man: Mike S.
GforceJunkie
Real Name: Mike S.
Re: Caprc 5-27-12 match AAR
Thanks Mike
Kerplow
Post by Kerplow »
derp, why is there no delete feature? :?
Dirtykoala wrote:Keep the streets safe, ban thinking.
