Fundamentals of Marksmanship
- Seth8541
Ive been meaning to do some sort of write up on the Fundamentals of Marksmanship.The following is that write up. These are the absolute basics but also the essentials and the foundation upon which all good marksmen are built. If anyone has anything to add, please do. This is just to serve as a guideline for the beginners who have questions on there shooting positions, trigger control, etc. These are all things that the shooter can practice in his or her home and at the range. Hope this helps some of you out.
Elements of a Good Shooting Position:
a) BONE SUPPORT
1. The weight of the weapon should be suported by bone rather than muscle because muscle fatigues whereas bones do not.
2. The shooter must establish a strong foundation for his rifle by utilizing bone support. This will enable the shooter to relax as much as possible while minimizing the movement of
the weapon due to muscle tension.
b) MUSCULAR RELAXATION
1. Muscular relaxation helps the shooter hold steady and increase the accuracy of his aim. Muscular relaxation allows the shooter to use maximum bone support which creates a
minimum arc of movement and consistancy in resistance to recoil.
2. There is no way the shooter can have muscular relaxation without bone support. During the shooting process, the muscles of the body should be relaxed as much as possible.
Muscles that are tense will cause excessive movement of the rifle, thereby disturbing the aim. When proper bone support and muscular relaxation are not applied, the rifle will
never settle into an aiming point, thereby making it impossible for the shooter to apply trigger control to deliver a well-aimed shot.
3. Only through PRACTICE and achieving a natural point of aim will the shooter be able to apply proper muscular relaxation.
c) NATURAL POINT OF AIM
1. The point at which the rifle naturally rests in relation to the target when the shooter is completely relaxed.
2. Once the shooter is in position and aimed in on target, the method for checking NPA is for the shooter to close his eyes, take a couple of breaths, and relax as much as possible.
Upon opening his eyes, the scopes crosshairs should be positioned at the shooters desired aiming point.
3. Since the rifle now becomes an extension of the shooters body, it is necessary to adjust the position until the rifle rest naturally at the preferred aiming point on the target.
4. Once the natural point of aim has been determined, the shooter must hold his position in relation to the target to maintain his natural point of aim. In all shooting positions the NPA
can be checked and readjusted periodically.
FACTORS COMMON TO ALL SHOOTING POSITIONS
These factors are common to supported and unsupported shooting positions. They involve building a SOLID foundation from which the rifle can be fired. Once the shooter is satisfied with the stability of a position, it should not change except for minor variations to accomodate different typed of supports.
a) PLACEMENT OF THE NON-FIRING HAND AND ELBOW.
The exact placement of the non shooting hand and elbow will depend on the height of the support used. For a very low prone position, the non shooting hand will grasp the rear sling swivel (rear bag) in a fist or it might lie flat on the deck. The elbow rest comfortably without strain.
b) RIFLE BUTT IN THE POCKET OF THE SHOULDER.
The shooter places the rifle butt firmly into the pocket of his shoulder. The proper placement of the butt helps steady the rifle, prevents CANTING, prevents the rifle butt from slipping in the shoulder during recoil, and lessens the effect of the recoil.
c) GRIP OF THE SHOOTING HAND.
The shooting hand grips the stock firmly, but not rigidly. A firm handshake hold. The thumb extends over the small of the stock to enable the shooter to get a good grip. A proper grip permits the trigger to be pressed straight back to the rear without disturbing the aiming process.
d) REAR ELBOW.
The placement of the rear elbow gives balance to the shooters position. Correctly positioned, the elbow helps form the shoulder pocket. The exact location of the elbow varies with each position.
e) STOCK WELD.
The stock weld is the point of firm contact between the shooters cheek and the stock. The firm contact between the head and the rifle enables the head and rifle to recoil as one unit, facilitating rapid recovery between rounds. The stock weld also enables the eye to be positioned the same distance behing the eyepeice (eye relief) of the scope each time the rifle is fired. This garantees the same field of view with each sight picture, further assisting in accurate aiming.
SUPPORTED POSITION FUNDAMENTALS.
a) Avoid touching any part of the support to the barrel. This will interupt the barrels natural vibrations, and can throw the round off.
b) Cushion the rifle on the support. This will keep the weapon from sliding around and steady the position.
c) Do not allow the side of the rifle to rest against the support. The rifle will recoil away from the support and can throw the round off.
SCOPE SIGHTING TECHNIQUES
a) Scope shadow.
During aiming, the shooter must ensure that there are no shadows in his field of view. He should see a clear black circle inside the scope. If the eye is to close, to far away, or off to
one side or the other, the shadows will appear. This will throw off shots fired. If a cresent shaped shadow is present, the eye is off center in relation to the scope. The shadow will
have the effect of pushing the shot fired in the direction opposite of the shadow. The shooter must adjust his position until the shadow disappears.
b) Eye Relief.
Eye relief is defined as the distance the shooters eye must be positioned from the eyepeice lens for the scope to function properly. If proper eye relief is not maintained, recoil may
cause the shooter to recieve a blow to the head (scope bite, magnum eyebrow, etc). Eye relief must be consistant for every shot.
c) Sight Picture.
1. Sight picture is the correct placement of the crosshairs on the target for the desired impact. For a correct sight picture, the point of intersection of the crosshairs is placed in the
center of the target mass resulting in a quartered target.
2. THE SHOOTERS ATTENTION SHOULD BE ON THIS INTERSECTION OF THE CROSSHAIRS AND NOT THE TARGET. The shooter should focus on the crosshairs without straining his eyes.
Intense concentration will eventually cause the image to blur. If the shooters is having trouble focusing on or seeing the crosshairs, his scope may need to be refocused.
TRIGGER CONTROL
The ability to move the trigger straight to the rear allowing the hammer to fall without disturbing the sights.The shooter should fire the shot exactly when the rifle settles to his aiming point, but it should be a subconscious effort not to disturb the crosshairs. This way, if the shooter can move the trigger without thinking about it (subconsciously), he can
concentrate on the crosshairs and getting his round on target.
2 TYPES OF TRIGGER CONTROL
a) Uninterrupted.
This is the preferred method. Once pressure is apllied, firing of the shot is completed. The shooter is committed to an unchanging rate of pressure, no speeding up, slowing down or
stopping.
b) Interuppted.
This method of control is used in when the rifle will not settle into position, forcing the shooter to fire the shot when the target comes into his aiming point. Also called "timing you
shot". The shooter takes up initial pressure and begins normal trigger control. He then holds his position until he focuses on his crosshairs. He then moves the trigger until the shot
breaks. The shooter should not force his rifle by steering it into his aiming point. He should let the rifle move naturally toward and away from the target. If the rifle is moving
towards the target, the shooter continuously applies trigger pressure. If the rifle is moving away from the target, the shooter holds his position until the rifle starts drifting back
toward his aiming point. He then applies pressure to the trigger. If the shot breaks as the crosshairs are moving towards his aiming point, the shot will normally be inside his call.
FINGER PLACEMENT ON THE TRIGGER.
Finger placement on the trigger is correct when it allows the trigger to be pressed straight to the rear without disturbing the crosshairs. This will vary greatly from shooter to shooter and depends a great deal on the size of the shooters hand and his grip.
Errors in Trigger Control
a) Flinching. The shooters reaction to the anticipation of recoil of the exploding round.
b) Bucking. An attempt by the shooter to take up the recoil just before the rifle fires, by tensing up his shoulder muscles and moving his shoulder forward.
c. Jerking. An attempt by the shooter to make the rifle fire at a certain time by rapidly applying pressure on the trigger and disturbing the alignment of the rifle.
FOLLOW-THROUGH
The continuous application of the fundamentals of marksmanship after the shot has been fired. The shooter shouldnot shift his position, move his head, or let the muzzle of the rifle drop until a few seconds after the rifle has been fired. Follow-through ensures that there is no undo movement of the rifle until after the shot has been fired. This will also enable the shooter to observe the strive of the round in relation to his aiming point, enabling him, if necessary, to adjust his aiming point and fire a second round.
BREATH CONTROL
a) Natural Respiratory Pause.
The point where the shooter is completely relaxed in his resiratory cycle. The point where the shooter takes a breath and exhales. This is a shooters NRP. Normally last just seconds during normal breathing, but can be extended more for some shooters. This is the point at which you want to fire your shot. This pause should last as long as the shooter feel comfortable with it. It depends on the physical condition and the lung capacity of the individual. Obviously, holding your breath longer that what is comfortable will cause a lack of oxygen that can deteriorate vision and affect the shooters ability to focus on the sights.
Techniques for Natural Respiratory Pause.
a) Normal Breathing
The shooter breathes normally, and as he approaches taking the shot, he pauses, gets his point of aim, applies trigger pressure, and takes his shot. It is easier to obtain a good sight picture when breathing stops because the movement in the shooters chest, abdomen, and shoulder stops. This entire shot process takes place during the shooters Natural Resiratory Pause.
b) Decreased Breathing.
As the shooter approaches his shot, he applies his initial trigger pressure and decreases his breathing. He starts getting his aiming point as his breathing decreases to a pause. He ca achieve his proper aiming point during shallow breathing because he is not moving as much. He then pauses, obtains a good sight picture, and applies continual pressure to the trigger until the shot breaks.
c) Cardiopulmonary Pause.
As the heart beat is transmitted through the body, it causes a corresponding movement to his rifle. This is particularly apparent in an unsupported shooting position and affects shooting at long ranges. The heart beat is noticable by the vertical movement of the crosshairs in the scope. To shoot effectively, the shooter should strive to fire the rifle so the trigger breaks at the lull of the heart beat for each shot.
a) BONE SUPPORT
d) REAR ELBOW.
e) STOCK WELD.
a) Scope shadow.
b) Eye Relief.
c) Sight Picture.
TRIGGER CONTROL
a) Uninterrupted.
stopping.
b) Interuppted.
FOLLOW-THROUGH
BREATH CONTROL
a) Normal Breathing
United States Marine Corps 1997-2005
2/3 Scout Sniper Platoon 1999-2002
3rd Marine Division Scout Sniper Instructor 2002-2005
- Connor P Price
- Real Name: Connor P Price
Re: Fundamentals of Marksmanship
Seth, thank you very much for the write up! It isn't often that beginners are able to get important info like this from somebody with credentials like yours.
- Seth8541
Your welcome bud. Its my pleasure. Ill try to post some more write ups on here soon. Mostly stuff for the beginners and hopefully enough info to get them started.Connor P Price wrote:Seth, thank you very much for the write up! It isn't often that beginners are able to get important info like this from somebody with credentials like yours.
shooter65
- Real Name: Larry Flynt
Dive N Shoot
- Real Name: Mike M
Thanks for all the good info. Another tip that has helped me out a lot, is to make sure I focus the scope and then slightly bob my head up and down, and side to side to make sure the reticle isn't bowing or moving. That's how to make sure the parallax is set correctly and you'll hopefully hit what your aiming for.
Iloveguns wrote: Roxy pattern in camo would be cool.
ColdSteel wrote: Damn dude!? You use your hands?
Kinky...
- Seth8541
+1Dive N Shoot wrote:Thanks for all the good info. Another tip that has helped me out a lot, is to make sure I focus the scope and then slightly bob my head up and down, and side to side to make sure the reticle isn't bowing or moving. That's how to make sure the parallax is set correctly and you'll hopefully hit what your aiming for.
Parralax.
The apparent movement of the crosshairs across the target when the position of the head is slightly moved.Parallax comes from the image of the target not being focused on the same plane as the reticle.
snappy
- Real Name: Brad Bolves
Everybody needs to review these fundamentals of marksmanship. Good write up Seth.
Just rember B.R.A.S.S.
Breath. Take two deep breaths to clear the lungs and thoughts, then got into your natural breathing cycle.
Relax. Bone support, relax the body and calm mind.
Aim. Natural point of aim, and proper sight picture.
Stop. Stop at the bottom of your breath cycle. you will find it stops at the same point most of the time, and your heart slows on the exhale cycle.
Squeeze. The the triger straight back and stay on the triger untill the recoil cycle is finished.
Repeat this cycle thousands of times.
There are no stupid questions, just stupid people asking questions
- buffybuster
- Real Name: Enrique Cancion
Brad,
I find it easier to remember : Make the Shot....Don't Fuck Up
snappy
It's the dont fuck up part that I have the most trouble with.
- buffybuster
Me more than you.... Happy Thanksgiving.snappy wrote:It's the dont fuck up part that I have the most trouble with.
- chuckshoots
- Sling User
this was very useful. i went to the range with my new rifle and put a snap cap or two in my mag randomly and found myself jerking when I came across the snap cap while shooting. but now after reading this again and practicing some dryfiring I am getting better, hell yea.
'its what you do right now that makes a difference'
