[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
• View topic - CaPRC 4/22/12 AAR
It is currently Mon Apr 29, 2024 6:06 am
Post new topic Reply to topic  [ 8 posts ]
 Post subject: CaPRC 4/22/12 AAR
PostPosted: Mon Apr 23, 2012 2:07 pm
We had 23 shooters show up to shoot today's match out of 26 RSVP's.
We had five 1st time Caprc match shooters.
Brad ran the match.
JoeV, Randall & Charlie helped run the line.
Total round count for the day was 58.
There were 10 stages with 1150 total points possible.
Match rules:
Bolt must be open during any position changes.
5 rounds maximum in the gun at any time.
Support side means support side eye and trigger finger.
Unsupported positional stages use NRA legal positions only.
400yd coldbore
On the start signal, engage the 6" plate with 1 shot from the prone position. Start position is standing behind the prepped rifle, loaded magazine with the bolt back.
70 points for a hit
70 points possible
60 seconds prep, 15 second shoot time.
100yd jumping poolballs
Round count: 10
On the start signal, engage the solid poolballs with 1 shot each from the prone position. The 8 ball is optional. A hit to the 8 ball without also hitting all other solid balls causes the shooter to lose all points.
10 points per ball except the 8 ball is worth 30 or zero points if all solids are not hit.
60 seconds prep, 25 jumping jacks, 60 second shoot time.
Pack support
On the start signal, engage the 300yd ipsc with 6 shots from the prone position off a pack. You may not use a bipod or rear bag. The rifle must only be supported over a pack.
Scoring per the target
120 points possible
60 seconds prep, 40 second shoot time.
Sitting unsupported
On the start signal, engage the specified 100yd ipsc target with 8 shots from the seated position.
160 points possible
Kneeling unsupported
On the start signal, engage the specified 100yd ipsc target with 8 rounds from the kneeling position.
160 points possible
60 seconds prep, 90 second shoot time.
Random callouts
On the start signal, engage the specified green targets with 1 shot each from the prone position as they are called out. No artificial rear support may be used, bare hand only.
The targets are the following: half-size ISPC at 600, 10" dot at 500, 8" dot at 400 and 6" dot at 300
20 points per hit
160 points possible
60 seconds prep, 100 second shoot time.
Kneeling supported transistions
On the start signal, engage the 350yd hostage, 200yd little man and 100yd 2" shoot-n-see dot from the kneeling position over the bench in the following order: 100-200-350-200-350-200-100. No artificial rear support may be used, bare hand only.
Round count: 7
105 points possible
60 seconds prep, 70 second shoot time.
Stressfire
On the start signal, run to your rifle and engage the 200yd little men from left to right with 1 round each. Shooter starts with 1 round in his hand and must retrieve each additional round from the bench behind the firing line.
25 points per hit
Standing unsupported
On the start signal, engage the specified 100yd ipsc target with 5 rounds from the offhand position.
125 points possible
60 seconds prep, 80 second shoot time.
Hotbore
On the start signal, engage the 100yd 3/4" diamond with 1 shot from the prone position.
50 points for a hit
50 points possible
60 seconds prep, 10 second shoot time
 Post subject: Re: CaPRC 4/22/12 AAR
PostPosted: Thu Apr 26, 2012 8:46 am
For all you first time shooters: there is no where but up to go from here.
Only a fool or a desperate man would fight a fair fight
PostPosted: Thu Apr 26, 2012 9:17 am
Congrats to the winners. Hope the newbies had a goodtime.
Ray, great shooting, your "beginners luck" continues...
PostPosted: Thu Apr 26, 2012 11:15 am
Did anybody happen to find a Straightlaced Rear bag that I think I left behind on Sunday? Looks like this:
Let me know if you found it.
Thanks
PostPosted: Thu Apr 26, 2012 11:21 am
Someone had it, maybe Rich grabbed it?
PostPosted: Thu Apr 26, 2012 2:33 pm
Brad said he left a black jacket or windbreaker.
Did anyone pick one up?
PostPosted: Thu Apr 26, 2012 9:54 pm
Just checked all my gear. I didn't pick it up.
PostPosted: Sun Apr 29, 2012 8:29 pm
Prone Shooter
Users browsing this forum: No registered users and 40 guests
