[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 384: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
• View topic - CaPRC Tactical Rimfire match AAR 4-15-12
It is currently Mon May 13, 2024 10:31 am
Post new topic Reply to topic  [ 20 posts ]
PostPosted: Sun Apr 15, 2012 8:14 pm
We had 10 shooters show up to shoot today's match.
Mike S. and John Lee ran the match.
Everybody pitched in to help run the line and spot.
Total round count for the day was 81.
There were 10 stages with 1060 total points possible.
After aprox. 1/2 hour of time to zero and confirm dope, the course of fire was as follows:
75yd Cold bore
Start position: Standing at yellow line, rifle on ground, bolt open.
On the beep, engage the 2" dot at 75yds.
60 points for a hit.
60 points possible
60 seconds prep, 30 seconds shoot time.
75yd Keypad
Round count: 10
On the beep, engage the target at 75 yards from the prone position with
two rounds on each of your numbers. Odd shooters shoot odd numbers
(1,3,5,7,9), even shooters shoot even numbers (0,2,4,6,8)
10 points for each shot within the number box
60 sec prep and 90 sec shoot time.
75yd diamond.
Start with 2 loaded magazines with 4 rounds each on the back benches
& unloaded rifle on the ground. On the beep, retrieve magazine,
load rifle, engage target with 4 rounds, retrieve second magazine from
bench, reload, and fire 4 rounds.
Target scored as indicated .
160 points possible.
60 seconds prep, 90 second shoot time.
75yd weak side dots
Start position: Prone behind rifle.
On the beep, engage the five 1" dots at 50yds with 1 shot each from the
weak side, with weak trigger finger.
60 seconds prep, 60 seconds shoot time.
200yd Steel option.
On the start signal, engage either the yellow 10" or 6” steel target
with 5 rounds.
You must call out what target you are shooting.
15 points per hit on the 10” target, 30 points per hit on 6” target.
150 points possible.
60 seconds prep, 90 seconds shoot time.
125yd Barricade
Start position: Standing at barricade, rifle at port arms.
On the beep, engage yellow 8” steel target with 2 shots from each
level of the barricade.
120 points possible.
35yd hostage
Start position: Sitting
On the beep, engage the hostage targets from the seated position with
two rounds on each bad guy.
10 points for each bad guy hit or and -10 points for each hostage hit.
-80 to 80 points possible
60 sec prep and 60 sec shoot time.
35yd 5 dot drill on 1/2" dots.
Round count: 20
On the beep, engage the 1/2" dots at 50yds with 1 shot on each dot
from the prone position.
Bipod support only, no rear bag, shooting glove or shemagh.
Bare hand only.
5 points per dot.
60 seconds prep, 180 seconds shoot time.
35yd Standard KYL.
Round count: up to 5
On the beep, engage the circles from largest to smallest, stopping
if you do not believe you can make a sure hit. A miss causes shooter
to zero the whole target.
Points are 10, 15, 20, 30 & 40.
115 points possible.
35yd Shapes
On the beep, engage your targets with 1 round each.
10 points per target, 25 for bonus target
75 points possible.
830 Evin G.
805 John L.
740 Jeff B.
735 Mike S.
720 Cameron W.
710 Steven R.
685 Randy C.
600 Rich C.
510 Dan K.
290 Mike F.
Congratulations to Evin, John, and Jeff to taking home dogtags.
Next match: June 24th.
Pic of score sheets will be posted tomorrow.
PostPosted: Sun Apr 15, 2012 8:45 pm
Mike, thanks for another fun match.
Pics from this morning's match:
http://www.flickr.com/photos/john_n_lee ... 463340184/
Scoresheet:
PostPosted: Sun Apr 15, 2012 9:09 pm
Lots of fun today guys! Thanks Mike for putting the match together.
Thanks also to Steven, John Lee, and everybody else who helped out.
PostPosted: Sun Apr 15, 2012 9:22 pm
Thanks to Mike for running the match,and it was good shooting with all of you folks.
I had a great time today despite being seriously out of practice. Can't wait for the next one.
PostPosted: Mon Apr 16, 2012 4:14 am
Damn, that was a high scoring match. Good job guys looked like a fun match.
Only a fool or a desperate man would fight a fair fight
PostPosted: Mon Apr 16, 2012 5:49 am
Thanks Mike and John... And a special thanks to John for the use of the rifle and ammo. I really rocked with that rifle. Now if I hadn't been so blind, I could have come in 2nd. Oh well still had fun
PostPosted: Mon Apr 16, 2012 8:50 am
Here's a few pics that I snapped at the match.
You do not have the required permissions to view the files attached to this post.
PostPosted: Mon Apr 16, 2012 8:52 am
PostPosted: Mon Apr 16, 2012 8:57 am
PostPosted: Mon Apr 16, 2012 9:18 am
PostPosted: Mon Apr 16, 2012 12:33 pm
PostPosted: Mon Apr 16, 2012 2:10 pm
Nice to see some one else besides John taking some pics! Will try to take some next weekend so you can have a break John!
PostPosted: Mon Apr 16, 2012 3:51 pm
Sunday's videos:
PostPosted: Mon Apr 16, 2012 6:11 pm
Fantastic match Mike and John, can't wait to shoot it again.
PostPosted: Mon Apr 16, 2012 6:31 pm
Don't thank me. Thank Mike. Mike puts on these matches. I just ran the timer on one of the relays. This is really no different from the other shooters helping to spot or pulling targets.
PostPosted: Mon Apr 16, 2012 6:41 pm
PostPosted: Mon Apr 16, 2012 6:59 pm
Thanks to Mike and his minions for putting on another fun match. I am already looking forward to the next one, too bad we have to wait so long.
Overall, I think the match went well. After some pretty low scores last match, I loosened things up a bit, perhaps too much. I moved some targets 25% closer, yet the hit ratio went up like 80%! Alot of stages got cleaned by people, I'll have to fix that :) Get ready for the next match, it will be on the private Fort Angeles range so have your 0-100 dope dialed in and be ready for alot of positional shooting and props, barricades, etc.
PostPosted: Mon Apr 16, 2012 7:17 pm
From looking at the score sheet I would say the match is running about what it should for a monthly. It's more fun to hit targets than miss. Unless you have a shooter clean the match it is still providing an accurate assessment of skill.
PostPosted: Mon Apr 16, 2012 7:38 pm
Bench Shooter
Thanks for putting on a great match Mike! and thanks for letting me borrow your 10/22, had fun shooting it. Great day overall. Looking forward to the next one!
Users browsing this forum: No registered users and 21 guests
cron
