We had 15 shooters show up to shoot today's match out of 17 RSVP's.
Brad & Ryan ran the match.
6079Winston, johnlee, bcrich and NotoriousPDL helped run the line.
Total round count for the day was 50.
There were 10 stages with 1000 total points possible.
400yd coldbore
On the start signal, engage the 6" plate with 1 shot from the prone position. Start position is standing behind the prepped rifle, loaded magazine with the bolt back.
70 points for a hit
70 points possible
60 seconds prep, 15 second shoot time.
60yd poolballs
On the start signal, engage the poolballs with 1 shot each from the support side (support side trigger finger) prone position. The 8 ball is optional. A hit to the 8 ball without also hitting all other solid balls causes the shooter to lose all points.
10 points per ball except the 8 ball is worth 30 or zero points if all solids are not hit.
http://www.caprc.com/targets/mini-poolballs.pdfStage 3
Pack support
On the start signal, engage the 300yd ipsc with 6 shots from the prone position off a pack. You may not use a bipod or rear bag. The rifle must only be supported over a pack.
Scoring per the target
90 points possible
60 seconds prep, 40 second shoot time.
http://www.caprc.com/targets/ipsc15.pdfStage 4
Sitting unsupported
On the start signal, engage the specified 100yd ipsc target with 5 shots from the seated position.
http://www.caprc.com/targets/ipsc20.pdfStage 5
Kneeling unsupported
On the start signal, engage the specified 100yd ipsc target with 5 rounds from the kneeling position.
60 seconds prep, 70 second shoot time.
http://www.caprc.com/targets/ipsc20.pdfStage 6
Random callouts
On the start signal, engage the specified green targets with 2 shots each from the prone position as they are called out. No artificial rear support may be used, bare hand only.
The targets are the following: half-size ISPC at 700, 10" dot at 500, 8" dot at 400 and 6" dot at 300
20 points per hit
160 points possible
60 seconds prep, 80 second shoot time.
Kneeling supported transistions
On the start signal, engage the 350yd hostage, 200yd little man and 100yd 2" shoot-n-see dot from the kneeling position over the bench in the following order: 100-200-350-200-350-200-100. No artificial rear support may be used, bare hand only.
Round count: 7
105 points possible
Stressfire
On the start signal, run the 50yds to your rifle and engage the 200yd little men from left to right with 1 round each. Shooter starts with 1 round in his hand and must retrieve each additional round from the bench behind the firing line.
25 points per hit
Standing unsupported
On the start signal, engage the specified 100yd ipsc target with 5 rounds from the offhand position.
125 points possible
http://www.caprc.com/targets/ipsc25.pdfStage 10
Hotbore
On the start signal, engage the 100yd 3/4" diamond with 1 shot from the prone position.
50 points for a hit
50 points possible
60 seconds prep, 10 second shoot time
620 Randall R
590 Keith N
520 Charles R
510 Jose F
480 Joe V
450 Connor P
425 Mike S
410 Dave S
400 Evan G
340 Mike Y
305 Nathan W
280 Nick P
220 Chris S
205 Kevin S
100 Tim D
